Beeps after completion/failure of a print, but only during the specified hours
This plugin is designed to be used to notify when a print is complete. While gcode to beep on print completion can easily be added to the slicer/octoprint, I wanted a way to only beep during certain time frames as I don’t want my neighbors to hate me for my printer beeping at 2 in the morning.
Requirements
- Currently requires the use of Gcode M300 to trigger the beep
Active Hours
These settings define the hours the printer may beep when the printer completes. These default to 8am - 10pm as I won’t likely be checking my printer outside those hours.
Beep Tone Settings
If you want to change the tone, or duration of the beep the printer makes, these can be changed to modify that.
Can be configured for custom tones
Beep Settings
Notify On Pause: Allow notification on pause events Wait for Cooldown: Will delay the beep until the bed has reached the indicated temperature (while respecting active hours)
