Use a filament sensor to pause printing when filament runs out.
Pause print on GPIO filament runout sensor
The following needs to be added to the config.yaml:
plugins:
  filament:
    pin: XX
    bounce: 400
where XX represent the GPIO pin where your sensor is connected.
An API is available to check the filament sensor status via a GET method to /plugin/filament/status which returns a JSON
  • {status: "-1"} if the sensor is not setup
  • {status: "0"} if the sensor is OFF (filament not present)
  • {status: "1"} if the sensor is ON (filament present)
The status 0/1 depends on the type of sensor, and it might be reversed if using a normally closed switch.
A build using an optical switch can be found at http://www.thingiverse.com/thing:1646220
Note: Needs RPi.GPIO version greater than 0.6.0 to allow access to GPIO for non root and chmod a+rw /dev/gpiomem. This requires a failry up to date system.
