Support for the BTT TFT touchscreen firmware
OctoPrint-BTT TFT Touchscreen Firmware support
This plugin adds support for the remote printing features of the BigTreeTech TFT Touchscreen Firmware’s Touch Mode for OctoPrint.
This plugin does not interact with the firmware’s Marlin Mode - a normal serial connection between the TFT and the printer is sufficient.
Features:
- Automatically switch to printing mode on the TFT upon print start.
- Update the progress indicator on the TFT during print.
- Update the remaining time on the TFT during print.
- Update the Layer progress on the TFT (requires DisplayLayerProgress)
- React to the TFT’s Pause, Resume and Cancel buttons on in OctoPrint.
This is a fork of the M73Progress plugin, created by Cesar Vandevelde!
Install via the bundled Plugin Manager or manually using this URL:
https://github.com/jounathaen/octoprint_btt_touch_support/archive/master.zip
You can fine-tune the plugin’s behavior in the BTT TFT Touchscreen tab in the OctoPrint settings (don’t forget to restart OctoPrint to apply changes):
- Use time estimate: By default, the plugin uses OctoPrint’s built-in progress
estimate, which is based on the progress inside a G-code file. In some cases,
a better progress estimate can be calculated from the time elapsed and the
time remaining:
P = elapsed / (elapsed + remaining). This option is particularly useful for PrintTimeGenius users. -
Serial Port Number: The number of the serial port the TFT is connected to. If it is set to
0(default), all serial ports will be used, which could lead to issues if other plugins also utilize action commands.(Typically, your printer has two serial ports
1and2, of which one is the connected to your OctoPrint host and the other one to the TFT)
