Makes it possible to change the EEPROM values of Repetier Firmware through OctoPrint
This plugin is designed to get, change and save the values in the EEPROM of your Repetier Firmware based Machine
Features
- Load and edit the values stored EEPROM from the printer firmware.
- Save changes to the EEPROM on the printer.
- Backup and restore snapshot copies of the EEPROM data (new in V0.1.4).
Find it in the plugin manager or install manually using the archive URL
Firmware requirements
This plugin only supports Repetier firmware, version 0.92 and later. Use caution when restoring data from an older firmware version.
Screenhots
EEPROM Values Editor
Changed Values Display
EEPROM Backups
