Connect to devices attached to another host via Serial over IP
If you want to connect to a device connected to a different machine than you run OctoPrint on, this plugin is for you. You can add remote connections to the serial ports OctoPrint knows about and thus transparently access such a device as if it was plugged into your OctoPrint machine.
