Adds RGB LED support to OctoPrint with the ability to choose colors and effects based on the current status of your printer
OctoPrint-Rgb_status
Adds RGB LED support to OctoPrint with the ability to choose effects based on the current status of your printer
Install via the bundled Plugin Manager or manually using this URL:
https://github.com/EricHigdon/OctoPrint-Rgb_status/archive/master.zip
Running Without Root
Since OctoPrint should usually not be run as root, the default LED pin is 10 (SPI). For details about what may be required to use SPI on your instance, see https://github.com/jgarff/rpi_ws281x#spi
Reporting Issues & Improvments
If you encounter any issues or bugs with the plugin please feel free to make an issue on the repo. I also fully support additions to the plugin from third partys. If you have an idea or an already developed solution that would implement with the plugin well please submit it to the github repo and I will gladly consider additions and contributions.
See the github page for more details.
