Makes it possible to change the EEPROM values of Marlin Firmware through OctoPrint
Originally by Anderson Silva until 2018 development taken over by Charlie Powell in October 2020.
The Marlin EEPROM editor provides an easy to use, feature-rich UI to edit your machine’s configuration.
Features
- Load & parse the EEPROM data out of the firmware
- Edit many of the values configured
- Save EEPROM changes on the printer with a minimal number of commands
- Storage of data on the OctoPrint server, so it can be viewed while printer is disconnected or printing.
- Backup feature:
- Enabled saving configuration snapshots, restoring, downloading, uploading
- Display firmware info, including capability report
Be sure to check out the screenshots below for more details!
Find it in the plugin manager or install manually using this URL:
https://github.com/cp2004/OctoPrint-EEPROM-Marlin/releases/latest/download/release.zip
Firmware requirements
This plugin requires that you have both these items in Marlin’s Configuration.h file:
#define EEPROM_CHITCHAT//#define DISABLE_M503
In other words, EEPROM_CHITCHAT and the M503 command must be enabled - comment out disabling it.
New in Marlin EEPROM Editor V3.0.0
A complete re-write of this plugin, now V3!
Featuring:
- Python processing & storage, eliminating performance issues in the UI.
- Storage of data on the OctoPrint server, so it can be viewed while the printer is disconnected or printing.
- Brand new UI, written from the ground up.
- Includes new read-only mode, when the printer is printing
- All-new backup feature, allowing naming and storing of backups, so you can quickly swap between profiles and more.
- … and more!
For the full changelist please check out the release notes.
Screenhots
Firmware info overview
Configuration editor
Backup feature
Enjoying the plugin? Sponsor its development!
I am working on this plugin in my spare time, if you appreciate the work I have put in please consider sponsoring its development on GitHub.
Need help? Get in touch!
Whilst I don’t like bugs, I want to know where they are!
- Get in touch on the Github Repository
- Ask a question on the community forums
- Find help on the OctoPrint Discord Server
My other plugins
Check out some more of my plugins in the repository here
