Control your PSU Control with MQTT or Home Assistant
MQTT exposure for PSU Control
Exposes PSU Control switch on MQTT so you can access it from somewhere else. Supports Home Assistant discovery for easy setup.
This plugin does not connect a smart plug to PSU Control. If this is what you need , take a look at “PSU Control - MQTT” instead.
Please check the github repo for up to date information and more details
