Download and extract a thing from Thingiverse to your Octoprint instance
Quick Install
Install via the bundled Plugin Manager or manually using this URL:
https://github.com/appdevelopmentandsuch/Thingiverse-Downloader/archive/main.zip
- Install one of the following in order to view / upload STL files to your Octoprint instance.
- Install the Thingiverse-Downloader plugin either from the Plugin manager, or manually.
- Acquire an API key from the Thingiverse Developer Console (tutorial to come).
| Settings | Description |
| API Key | An API key / App Key acquired from the Thingiverse Developer Console found here. |
| Output Directory | The desired directory you wish to have the Thingiverse thing downloaded to. Recommend using models |
