Configure AutoLoginLocal from the UI with ease.
Allows for UI configuration of AutoLoginLocal - an OctoPrint feature that automatically logs in a user from a local network.
Do not use this if you cannot trust EVERYONE on your local network. And I really mean everyone. If you ignore this and then someone takes over your OctoPrint instance, installs malware on it and makes your printer print an endless stream of benchies, that's on you.
This plugin requires access control to be enabled & set up correctly on OctoPrint 1.4.0 or newer.
Problems, bugs, need help? Get in touch:
- on the OctoPrint Community Forum
- on the Issue Tracker
- on the OctoPrint discord
Support my work with OctoPrint
Thanks to JetBrains for sponsoring an open source license for their IDEs
AutoLoginLocal Configuration by Charlie Powell and contributors
